Usually on most CD & DVD disk players, theirs a small hole about the size of a pin head. It's located near the manual eject button, on the right hand side of CD/DVD door. Take a long needle, or paper clip "unbend the paper clip" so it's straight. Carefully stick the tool of choice STRAIGHT in the hole intill l the end if paper clip or needle stops, and you can feel some resistance then push slightly. the spring inside that your pushing on releases the disk. Hope this helps you out. Have a good rest of your evening.
Lynn
f you're trying to eject an external disk:
Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
If you're trying to eject a CD or DVD:
Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
If you're trying to eject a network disk:
Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
