By removing password on WINDOWS LOG-I, here a tip on how to remove the password.
# Before the windows system boot up press F8 then will appear Windows Configuration command then select SAFE MODE.
# Wait until it comes up to the screen and you will see the 2 USERS "ADMINISTRATOR" in "USERNAME".
# Go to Control Panel and select USER ACCOUNT.
# Click on "USERNAME" then remove the password.
# Restart your COMPUTER and the windows system will direct you to the DESKTOP.
Hope this might help you my instructions. Good luck!
As far as I know, there are a lot of tools and utilities that can be downloaded and used to recover, retrieve, reset windows password. However, I've tried a couple of these utilities through the years. The free software can help you, but you have to learn some computer skills and waste a lot time on learning. If you want to save more time, http://www.reset-windows-password.com/ho...
Read tutorial on computer password reset:http://www.windowspasswordrecovery.net/a...
You can log in with administrator account, If you didn't set administrator password then it is blank by default, at the log in screen press ctrl+delete admin log in windows will be open write administrator on username field leave password field blank and hit enter or use password recovery software http://www.stellarinfo.com/password-recovery.htm
How can i log on my computer i forgot my password
Check out this
http://pcsupport.about.com/od/tipstricks/f/forgetxppass.htm
hope help u
Four days ago, I found the password recovery software Windows Password Seeker which has been recommended at about.com and use it to remove my lost password successfully. It is a very easy and useful utility. Just follow the step-by-step instructions at Four days ago, I found the password recovery software Windows Password Seeker which has been recommended at about.com and use it to remove my lost password successfully. It is a very easy and useful utility. Just follow the step-by-step instructions at www.passwordseeker.com/howtouse.html
If you can not remember the windows admin password, try to reset it with a reset disk. Free download windows password unlocker from http://www.passwordunlocker.com/products/wpu.html and there is a .iso file included. Burn the .ISO file onto a blank CD which is so-called windows password reset disk. With this disk, you can reset the unknown password without erasing anything
SOURCE: I can't log in
Hey there - Try booting into safe mode
(hold F8 during boot up) choose the safe mode option. This should bring the administrative account available at the login screen. Hopefully you have not password protected it. If you can log into that account you can
remove/change the password settings for the your account under the "users" in the control panel settings.
NOTE* This fix assumes you're operating in Windows XP
