Question about Symbol Computers & Internet
Rreset symbol MC40 to factory default. There is information on the handheld using StageNow and additional files downloaded for the device function. I need to start over.
6ya staff
SOURCE:
Anonymous
  • 476 Answers
SOURCE: cannot download
Make sure you are trying to sync .MP3 or .WMA files.
If this is the case check out the error code number on the Microsoft website.
Posted on Feb 25, 2008
Randy Morton
  • 479 Answers
SOURCE: DS3300 when plugged in doesnt automatically download VFs
check the services to see if the dm1 service is started
Posted on Dec 16, 2008
Anonymous
SOURCE: RCA Pearl TH1602-A default formatting
first of all, you need to be running these tests on a FAT16/32 bit machine running windows 95/98. second, right click on the device in my computer -> properties and at the top it will state the format:
File System: FAT32
The device always retains its factory settings/formatting until it is plugged into a computer, just by having it plugged in a .ini file is created and settings are stored in it, including file name, system and usually the format version.
If a user re-formats this device, they may have (assuming they excel in computers as i do...) the knowledge to edit these settings. Good luck
Posted on Apr 03, 2009
Andrew Kowalski
  • 65 Answers
SOURCE: PDT 6846 Hex Image Modify Query
I have sofware to rebuild your hex files I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Posted on Jan 22, 2010
chadanthony0
Chad Powers
SOURCE: how to factory reset the device
There is a setup mode you can use to set the player back to factory default settings. From the main menu, just hit SETUP. In there, there should be an option called Load Default. This puts all the settings back to factory defaults.
From there, it's just a matter of deleting everything out of your Media and Data folders. Just plug it in to any computer and delete the contents of those two folders.
Posted on Oct 24, 2012
Reset boot
http://www.ptshome.com/MC3100/mc31xx_manual.pdf 31xx, xx means that any numbers go. Download the file and you`re in business to find out...
Aug 17, 2013 | Zebra Symbol MC3190G Handheld Mobile...
LS2208 reads @ as ] in SSCC label
In the Quick start guide, try scanning the "Set Defaults" barcode, This will restore the device to factory default.
Jun 06, 2013 | Symbol LS2208 Handheld
Function keys on MC9090
hi,
Sound like you need to look at your Keyboard mapping files, easiest way to fix this is to use Motorola System Configuration Manager - Downloadable from the Motorola website.
If the unit need to be restored to factory defaults, than a fast way is to run the Clean boot files from the SD Card also downloadable via the Motorola site - search for 'MC9090 Clean boot'
Mar 04, 2013 | Symbol MC9090-G Barcode Scanner
Where do i go on my phone motorola 75 to reset
Download "clean boot" files from support.symbol.com and run the files as stated in .txt file. This resets the device to factory defaults.
Aug 06, 2012 | Motorola MC75
I have a upro go I get an error window saying invalid master index file when trying to power up and play golf.
Welcome to Fixya
Sounds like there is a software issue with the device. Try to restore it to original factory default and test the issue again.
Restore the factory settings by going to the Device Settings screen within the settings menu. Under the Device Settings, choose Factory Defaults.
Thank you for using Fixya
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 12, 2011 | Callaway Golf Company uPro Handheld GPS...
How to factory default Mc75 device
Resetting the MC75
There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
card is not lost.
If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
boot.
Performing a Warm Boot
Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
Power button.
Performing a Cold Boot
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Motorola MC75
Factory reset d301+
i have the cd that would allow you to factory reset the device once installed reply to this i will sent you the executable ..
Jul 07, 2010 | D-Link DP 301P (DP-301P) Print Server
Jan 19, 2010 | Symbol PDT 6846 Portable Terminal
Garmin etrex gps
Most reset would revert the unit back to factory default and therefore may and could erase all user stored settings and configurations.
Having been forewarned, Pressing "up"+"enter" keys while powering up the eTrex will reset the eTrex to factory defaults. So, all pressets and data will be lost.
Additionally, you may be able to do bypass and other tricks using the "Secret Startup Commands for Garmin handhelds".
Tight lines and hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 04, 2008 | Garmin eTrex GPS Receiver
Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
Jan 31, 2008 | Symbol LS2208 Handheld
Computers & Internet Logo
32 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
