The number of print pages for the Booklet Creation job exceeded the number of maximum pages. Reduce the print pages or disable the Booklet Creation feature.
There are a lot of different errors you can get with printers and copiers. to be able to get help, you have to say what the error is? If there was only one error you could get, then that would be a different story.
I m getting problem with IOCTL error with my sandisk 1gb pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
