SOURCE: Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
SOURCE: INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
SOURCE: Samsung SGH-t429
I accidently locked my boyfriends sgh-t429 Samsung and i need to unlock it quick!
SOURCE: Emergency calls only? Is phone locked? Is there
The is a problem with you cell phone service.
Call you cell phone provider or take their store.
If this helps please vote for my solution.
SOURCE: can't call or recieve calls. when i try it comes
turn off the phone for a while & turn on then try it.
