Hello Anthony, to replace the batteries, you must disassemble the pads and remove the 3 screws of the speaker cover, there will appear the batteries
You must replace with similar batteries
re-close the speaker covers, place the pads and let it charge for 12 hours, so that the load is effective
I hope you can solve your concern
Greetings Franco Dosil
Hola Anthony, para reemplazar las bater?as, deber?s desarmar las almohadillas y retirar los 3 tornillos de la tapa del parlante, ah? aparecer?n las bater?as
Debes reemplazar por bater?as similares
vuelve a cerrar las tapas de los parlantes, colocar las almohadillas y dejar cargar por 12 horas, para que la carga sea efectiva
Espero que puedas resolver tu inquietud
Saludos Franco Dosil
https://docs.sony.com/release/MDRRF985RK_EN_FR.pdf
SOURCE: Battery replacement
Oh, I found it!
What comes off is the T-shaped chrome piece on the topside. To pry it off, start at the blunter end of the H500, on either side of the USB port. And note that this chrome piece is just a veneer, sitting on top of the black (in my case) plastic housing.
This web page shows and discusses the disassembly process, on the way to reusing the H500 innards for something else:
http://badacetechshow.com/BT%20Hat%20Pg.2.html
See ya...
-- Mark
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
SOURCE: I have searched the web
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work (be able to be charged using the cradle) in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries. NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
SOURCE: Can I replace the ear
Hey--it was reassuring to see that I'm not the only one with this question. Lots of places (Staples, Radio Shack) have the right size replacements, but it takes a little more digging to be sure you can find something more than what looks like doughnut-shaped packing material. B&H Photo Audio does, and here's a link: http://www.bhphotovideo.com/c/product/582208-REG/Pearstone_8091000_Replacement_Earpads_Pair.html
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
