Sad to say it's likely to be 1 or more transistors in the power amp circuit, although there are other possible causes.
Luckily the repair manual is available (hifiengine.com) and the power amp is built with discrete components, so it should be easily repaired
Most common causes would be an output transistor or dry solder joint(s) due to transistors / resistors getting hot and cooking a solder joint or 2.
Inspect all solder joints carefully with a magnifier, looking for signs of localised heating/burning and/or crysalisation of the solder.
It's normal to replace output transistors as a matched pair even when only one has failed, to minimise distortion. Replacement transistors should of course be as close to the original specs as possible (or better) if genuine parts are not available. The bias will need to be adjusted as per manual (1.5mV emitter to emitter of output transistors).
Good luck.
SOURCE: Possible Tuner Problem?
Go here and get the latest firmware. Find your model on the left side of the web page. http://www.pasctraining.panasonic.com/SpecialApplications/ProductFirmwareDownloads/downloads1.asp
SOURCE: QUAM TUNER
Doubt it. We ran HD through our small CATV system using consumer grade modulators but could only get them on the AIR frequencies, as we had very limited bandwidth as we had to carry 64 analog channels plus digital HITS packages for our Motorola DSxxx series boxes. Try plugging the CATV feed into the ANT input and do an autoprogram, or tell the tv to look on the AIR frequencies when it asks if you have CATV or AIR. Worth a shot though.
SOURCE: left channel not working
Thanks, yesterday i tried changing the speakers from right to left, the problem still remained on the speaker getting connected to the right channel. Later i pulled out the speaker wires from the reciver's end for the right channel, cut them and pulled out new strings from the insulation, twisted them and inserted, the speaker is working fine, though not 100% but close to left channel. I guess the problem was old strings in the wire which had got over twisted and were not parallel to each other.
regards
Swamy
SOURCE: I have an old Sansui 400 receiver. I get no sound
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Testimonial: "very helpful"
SOURCE: Sony STR-DH510 Multi-channel AV receiver
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
