Computers & Internet Logo
edelberto baluran Posted on May 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove back panel of viewsonic va2046 - ViewSonic Computers & Internet
Franco Dosil
Level 3:
Top Expert:
  • ViewSonic Master 10,542 Answers
  • Posted on May 13, 2019
Franco Dosil
ViewSonic Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377283
Points
178965
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets
I hope you can disarm it, comment the results
Greetings Franco Dosil
Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas
Espero que puedas desarmarlo, comenta los resultados
Saludos Franco Dosil
http://www.viewsonicglobal.com/public/products_download/36/29622.pdf
http://www.viewsonicglobal.com/public/products_download/36/29639.pdf
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on May 19, 2009
SOURCE: how to remove back panel
there might be screws behind the foot. remove the foot base first...then look to see. alot of these screens are pressure tab case fasteners.they use screws to lock in the cover. after that a smakk flat screwdriver along the lower sides will reveal is the cover is tab fixed .\
good luck
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
2answers
I have a ViewSonic VA703B, I need to get it working but I cannot get the back of. How can I get the back of.?
gregmclure1, Most rear covers kind of snap-apart from the front plastic bezel. need to remove pedestal first. Best thing to do ,go visit YOUTUBE view typical "LCD monitor disassembly" and or "LCD monitor repair" videos FYI. PROTECT THE LCD PANEL AT ALL TIMES!! You may even find a video of someone working on a VIEWSONIC monitor. Hope this helps. If it does, then rate this on fixya.
12fixlouie
ps What will you be working on once the back is removed? Do you know what to look for?
How to take apart viewsonic w2235 moniter?
There are about 8 screws on the back of the monitor. Remove them, and the monitor's back panel will come off, then you can remove more screws to get further into the monitor. By the way... what are you trying to do by taking your monitor apart?
good luck
1helpful
How do I get my Viewsonic VX922 LCD monitor apart? I have removed the 4 corner screws and the stand, but the back seems to be stuck solid.
in a similar situation the solution was an Ipod case opener used along the perimeter to release the plastic catches..
1helpful
2answers
Remove back panel
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Viewsonic 32" TV
You can open it when remove all screws at the back, from the stand also (under the TV).
Then carefully remove the snap-in shell ( front and back). TV is one compact part and plastic shell is snapping ( front and back) + stand, on the screws.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
