First things first...check for fault codes..If it was your immobilizer you would have a light on to tell you -(flashing as you turn the key to crank the engine )... and you would have no spark..at the plugs at all.
If your engine has compression, fuel and a spark it will run...
You need to check for fuel and spark as your starting point for trouble shooting your cranks no start problem.
Press and hold the shooting mode and LCD illuminator buttons simultaneously for about two seconds (both buttons are marked "FORMAT" in red). A blinking "For" will appear in the display. Release the two buttons and then press them again.
Full instructions are in the "Format the memory card" section of the manual (page 21 in my copy). If you need a manual, you may download a copy from here.
This code means that there is/ was a misfire detected in the #3 cylinder, if you wish to trouble shoot the problem your self, I will need to know what kind of ignition system you have. ie. coil over plug or points.
It's the "shooting mode" button on the top rear of the camera -to the left of the eyepiece - looks like 2 or 3 sheets on top of each other. Hold it down and use the wheel to select the self-timer clock.
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600?
http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b11&num=12
Select ISO setting this way:
http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b05&num=10
Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
