SOURCE: hard to start yz250 dirt bike 2001 4stroke
i used to own a yz426f and it had the exact problem... a fresh plug will fix your problem. change the plug and the bike will run great. also don't start the bike and shut it off , my bike would be fine if i started it and rode for a while getting to the proper heat range help save the plug. if my bike didn't start in one or two kicks it was usually the plug.
hope this helps
SOURCE: 1992 Pace Arrow Motor Home 454 Chevy...not getting fuel to start
After you dump the fuel in the throttle body it will continue to run on its own or die as soon as it burns up all the fuel you dump in? Do you have access to (Noid lights)? Are both plugs attached to the distributor?
SOURCE: why wont my 96 chevy cheyenne 5.7 run unless i put
Probally needs fuel pump. Pump is in the tank. remove gas cap listen when you first turn on key it will run for a few seconds.
Testimonial: "rite on man THANK YOU"
SOURCE: Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Testimonial: "Great reply thank."
