SOURCE: 500gb St ex hard drive suddenly disconnects when still plugged in
try to replace the cord you are using and then try to run it again. If it is work then the problem is the cord othewise the plug or the hard drive itself has a compatibility problem.
SOURCE: 500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies.
Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
SOURCE: I have a 500GB external SimpleTech HD. Tonight it
You've lost some data on the master file table---I did the same thing with a 320gb and was able to recover most of the files intact with a simple FREE file recovery program.
SOURCE: I have a 500gb simpletech hard drive that I have
The simplest way is to ask SimpleTech
Your Part number: PRO500Q
Customer Support Phone Number
Tel: (949) 477-7700
(6:30AM-5:30PM PST Mon-Fri)
or send them a tech support request at...
http://www.simpletech.com/webspeed/webtech/indextech.php
SOURCE: I have my Simpletech 500gb drive pluged in but
Okay, so it should be picking up with that machine. First try re-seating all cables (power and USB both sides) and also try plugging it into a different USB port. Be patient and give it a few minutes to find it. Let me know whether or not that works.
