SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
SOURCE: Ricoh Fax 1140L
The only reset there is for it is to turn it off, wait 30 seconds, and turn it back on again. If it appears again, it needs service in case the thermistor needs to be replaced or something else.
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters
Information
It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured.
From the front panel:
The screen will read Cfg param val: 26
Screen will read Test -001+
SOURCE: Canon L220 Fax ##323 Check Printer
Canon manual says ##323 is the laser beam detector defective. Try to substitute the laser assembly (RG5-3497)
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is
plugged directly from the wall jack into the back port of the fax
machine that is marked "Line" or "To Wall Jack", or that has a
wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line
such as splitters, credit card machines, or telephone answering
machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
