The dead battery did not caused any damage, just was dead.
SOURCE: Replaced battery, started 5 - 6 times, new battery ded.
Nope, but they are usually near the battery, solenoid or starter (where main service wires are)
SOURCE: concern with the timing belt 1997 toyota avalon xls
The maintenance interval is 60,000 miles, but they usally last quite a bit longer before they fail.
This is a non-interference motor , meaning the valves will not hit the pistons if the belt brakes.
SOURCE: I have lost the instructions for my 347 pedometer
Exact Make, Model & MFG would be needed to get a manual. Should be able to find it on MFG site. Good Luck.
SOURCE: timing belt 2003 kia spectra
We tried to replace the timing belt ourselves, and even though we had done it fine on other cars, we blew the engine and had to replace it. It is NOT worth it!!!
SOURCE: the timing belt in my 2001 pt cruiser is broken.
Its got damage, bent valves. replace every thing on timing belt, tensioner, pulleys, water pump. The head needs to go to a machine shop and bent valves replaced.
