IBM Wheelwriter 50 series 2
SOURCE: IBM Wheelwriter 5
Is the hammer striking with no impression? (Try something with a carbon in it to see if it prints on the copy. If it does you have a ribbon problem. If the ribbon dosen't lift try wiggling the large black gear to see if it frees up. or your ribbon may be so old that it won't transfer the ink. If the hammer is not striking the plastic cap on the print soleniod is probably broken, they are available for 15.00 but are a little tricky to install.
DickyO
SOURCE: Need owner's manual for IBM/Lexmark wheelwriter 30 series II
I can send you acopy of a ww30 manual for 25.00
DickyO
SOURCE: IBM WheelWriter 30 Series II Operator Manual
The delay print and justify are both on the far rt. of the keyboard pressing these keys turns the features off and on. if this dosen't do it you're keyboard is bad.
DickyO
SOURCE: Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
SOURCE: needing bold typing on IBM Wheelwriter 6 Series II
To get bold you need a WW 10, 15, 1000, 1500 or any of the later models have this faeture.
DickyO
