Question about Daewoo Washing Machines
My Daewoo washing machine has refused to come on
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
DAEWOO,WASHING MACHINE.CDW-WD13WCS/RCS. Door will
This video will show you how to open your DAEWOO washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2013 | Daewoo DW500M Top Load Washer
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Washing Machines Logo
Top Daewoo Washing Machines Experts
Marvin
Marvin
Fahr Quad
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
