Re: How do i enter the four digit code into my Becker...
Yes to enter codes you must repeatedly press the corresponding station buttons 1,2,3 and 4.
Confirm the entry is correct by pressing down the seek button.
If it is good the CODE word will disappear.
Thanks Shaun but that is not working. So my code is 8376 - so i enter 8 into the first flashing code area and then I press 3 into the second flashing area etc etc and then press the seek button "^" ?Thanks Shaun but that is not working. So my code is 8376 - so i enter 8 into the first flashing code area and then I press 3 into the second flashing area etc etc and then press the seek button "^" ?
To enter the code I dont have to repeatedly push anything .... I just enter the code once and then it is there and then the next number until all four are in - then I press the seek "^" and then the first number (8) flashes again. The code was written on the owners manual.To enter the code I dont have to repeatedly push anything .... I just enter the code once and then it is there and then the next number until all four are in - then I press the seek "^" and then the first number (8) flashes again. The code was written on the owners manual.
The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
1. Turn on radio. The radio display shows "SAFE".
2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
5. The radio should unlock and be usable shortly afterwards.
6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
7. If you lose your radio code, contact your Audi dealer.
The sequence of programming for 2000 VW Cabrio radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
to be the code.
The following instructions will allow you to reset any GM (General Motors), Cadillac, Oldsmobile, Buick, Pontiac theft lock radio.
Requirements: the theft lock radio must be in "LOC" mode.
Procedure: 1. Turn the ignition ON (The radio should display "LOC") 2. Hold down the Radio Presets 2 and 3 buttons for six seconds 3. The radio display changes from LOC to a three-digit number. Write this number down. You now have fifteen seconds to complete the next step. 4. Press the AM/FM button 5. The radio display changes to another three-digit number. Write this number to the right of the first one. 6. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05 7. Call 1-800-537-5140 8. Press 1 then # (pound). You'll hear "Invalid Code, try again" 9. Press 139010 or 106010 or 206010 or 202107 then # (pound). You will be asked to enter your four or six digit code followed by * 10. Enter the number from STEP 6 then * 11. Listen to the four-digit number and write it down. It will be repeated twice 12. Turn the ignition ON (The radio displays LOC) 13. Use the MN and HR buttons to enter the code from STEP 11 14. Press the AM/FM button. The radio display changes to "SEC". Your radio is now "un-locked" and usable.
If
you fail to enter the correct code eight times, the radio goes into
INOP mode. You have to wait an hour with the ignition on before the
radio returns to LOC mode.
it depends on year of car and make of RADIOHERE IS THE SETTINGS FOR A 2002 AUDI A6 Quattro V6 2.7L Turbo (APB) engine code
For the Audi Concert Radio
YOU STILL NEED YOUR RADIO CODE TO ENTER THIS!!!!!!!!!!!! tell me if this work for you
Entering Anti-theft Code
correct order.
Note: Some European market Concert radios have a TP button instead of
the FM2 button, so the description above with those units would require
pressing the TP and the RDS buttons simultaneously.
Becker After switching on the unit the display shows 'CODE'
Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit
Regretfully due to reasons of theft or piracy we do not pass the radio codes here at FixYa. If you contact your local Mercedes-Benz dealer they will give you the 5 digit code. (You must have your registration and know the complete serial number of the radio)
AR82.60-P-7502-01A Coding Radio (MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
The code number for the radio is advised to you on the enclosed CODE CARD.
To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio (MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
The code number for the radio is given on the enclosed CODE CARD.
Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
