SOURCE: Electric Water Heater Problem
When an electric water heater fails to heat water, either the power to the water heater has been interrupted or there is a problem with the controls or the heating elements. 1) Be sure electricity is being delivered to the appliance. Check the main switch on the water heater and the circuit breaker (or fuse) that serves the water heater. 2) Check the high-temperature cutoff in the water heater. Open the panel, and push the reset button. 3) If these steps don’t solve the problem, call an appliance repairperson.
SOURCE: Electric water heater elements.
after you shut off electric and water and drain tank they are unscrewed. they make a large socket like wrench to remove i have also removed using a basin wrench
SOURCE: Hot water heater flow problems.
hey Bookie, those plastic inserts are kinda moulded into the nipples, so taking them out might be more than a feat,...did you solder the pipe to the female adapter ON the nipple? if you did you melted the plastic and that is what's your restricting your flo,......or (believe it or not) the inlet water valve isn't turned on all the way,.....close it then open it,..could have somethin stuck in it. let me know eh? thanks and good luck, cracklin joe
SOURCE: Rheem 83xr52-2 50 gal residential water heater.
You can open the top up again. I would not turn the temp higher than 130 degrees, maximum. However, there should be above the thermostat a red button. This is where the power wires connect to the thermostats and heating elements. Sometimes this button needs to be reset, press it and discern if you hear a click sound. This means that the high temperature safety switch has tripped open and you had to manually "reset" it. There are two thermostats by the way. The water heater usually works this way. There are two thermostats and two heaters. The upper tank heater turns on first and it heats the top half of the tank. Then when the thermostat above is satisfied it then allows the bottom heater to come on and heat the bottom half of the tank. You might want to set the bottom heater thermostat as well. This is made this way because it is actually faster and more efficient to heat the top half first and the bottom half secondly. Try this first with the reset button. We could check voltages, but that requires a level of knowledge and safety that I am not sure that you are comfortable with. Pictures of the upper and lower thermostats and connections will help if the "reset" does not do the trick. By the way, not meaning or implying anything, but did you move the thermostat in the right direction? Sometimes the dials can be confusing.
SOURCE: I have a GSW Series 5 water heater (electric). I
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
