Washing Machines Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer stopped adjutating but it drains the water out what is the problem
Anonymous
Level 2:
  • Expert 268 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
268
Questions
0
Helped
110374
Points
796
The agitator is driven by a couple of different methods. The first is the agitator is spline and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling.
If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Anonymous
Level 3:
  • Master 998 Answers
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
248601
Points
3069
Check agitator and spline and tranny
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
1helpful
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Washer won't stop filling
Does the water stop filling if machine is unplugged? If yes, bad water valve inside washer.
If water stops when unplugged, may be a faulty pressure switch or airdome hose came loose from switch - located in control panel - water level switch.
If water keeps filling and never overflows onto floor - likely that water is siphoning out drain hose. Raise drain hose higher or allow an air break at the drain hose exit.
1helpful
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
1helpful
Washer continues to fill and does not stop. is there a level or pressure switch that is problem or something else? Kenmore 80 series
if there is no water leaking from the unit.then stop the washer pull your drain hose up so it is at least as high as the top of the washer make sure not to to take it all the way out of the wall.you should here water draining out of the hose once the water has stopped restart you washer and it should stop filling.if it does not the yes you have a fill valve sensor problem.the drain hose usually always holds some water and during the filling process if the drain hose if very low it will cause the water to start gravity eeding out of the washer that is why raising the hose helps out.i hope this helps your problem.i would like to now how it worked out for you good luck.
The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
5helpful
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
3helpful
2answers
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Fridigidaire Model # FLXE52RB55 THE TUB FILLS WITH WATER , THE ADJUTATOR & DRUM ARE ADJUTATING AND SPINNING BOTH FUNCTIONING THE SAME DIRECTION SPINNING WATER OUT OF CONTROL
Likely the agitator ears are broken - or clutch is frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
