If you have a Hewlett Packard computer released after 2012, you can get the HP Support Assistant from the link below.
HP Support Assistant download
Remove HP Support Assistant from the Taskbar
Open the HP Support Assistant, select Updates and tune-ups , click Other settings on the bottom left, and uncheck the Taskbar options in the How would you like to be notified? section.
http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
I am assuming you are wanting install this on a HP machine, so all you should need to do, is go to the HP website if you use the machine you want to install it on, the web site should be able to detect, your make and model, and if any software is missing it will direct you to the page where you can download the software, and install it in the same way you install any other application in windows.
