SOURCE: How do I install fuel lines on a poulan chain saw
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
SOURCE: Looking for a Primer Blub for a Mcculloch PowerMAC
Hello Winston;
Even the new number you provided does not cross. Could your saw be a PM3216, model 11-600032-33? That does cross here:
McCulloch MTD
Chainsaws 32cc-35cc
and with better detail here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/MCC/11-600032-33-Mac-3216-06%2F93-IPL-211229/139.11-600032-33-Mac-3216-06%2F93-IPL-211229.1.59.1.html
See the "General Assembly" print; item 23; pn 224242-02.
M & D Mower
http://www.m-and-d.com/index.html
Has the above item available through arinet reasonably.
It follows:
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=224242-02&Quantity=0&SellerId=1017594&Username=Default
I am going to close this. We can continue to converse as before.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: which hose goes to which connection on a primer
Hello Ryan;
There is also a 11- prefix.
http://www.ordertree.com/modelinfo/MCC/21-600038-19-MacCat-Super-IPL-211318-01/139.21-600038-19-MacCat-Super-IPL-211318-01.1.59.1.html
Compress the primer, connect 1 hose, and release the primer. If it fills it is correct. I get conflicting reports on the carburetor connections, it may be model related.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Lou
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
