Question about Galaxy Cell Phones
My Galaxy J7 is showing a white circle battery charging indicator. Why is this happening? Just before seeing this my phone completely went dead (still had 60% power)plugged it in & now I get circle.
White circle charging indicator on Galaxy J7
    New Friend:
  • 25 Answers
How old is the device? If it's more than 3 Years old then odds are you are looking to get a new phone. After certain amount of time the phone is going to become incompatible with the new software which means you hardware cannot communicate with the software correctly so it doesn't show a correct battery charge. Most battery problems are not even battery problems, they just seem to be. Also if you are having a problem with your phone as far is it turning off by itself or closing out apps by itself then I would also look and see how full your storage is. If your storage gets to full then your phone will just quit working, because it needs some Storage to run the programs.
Posted on May 24, 2019
    Guru:
  • 531 Answers
Please describe what "Completely went dead" means.
Did it fully Power Off?
Did you have to hold the Power button down for a while to get the phone to go through a Restart?
Did the phone come back on when you pressed the Side button?
A little more detail, please
Posted on May 22, 2019
6ya staff
SOURCE:
Anonymous
  • 38 Answers
SOURCE: w850 flashing
Does the flashing screen is it works or not? If it works its the LCD thats making the flashing if it dosent its the software problem. If check that... try charging it.. if its charged its not the software problem..The LCD can be changed from a phone shop or tecnical shop and if you have some skills you can change it yourself but its best to bring it to the shop.
Hope this help!
Posted on Jan 12, 2008
Anonymous
SOURCE: cell phone won't charge/or hold a charge
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Posted on Feb 27, 2009
Anonymous
SOURCE: Samsung NC10 Screen goes white when plugged into Charge
I too had this problem with my NC10, and i found that on the back, the little slider holding on the battery casing was not in the locked position. As soon as I locked the slider, the problem was solved and has not occurred again.Might not be the case for all these posts above, but worth checking your before having to get involved with customer services etc.
Posted on Jan 12, 2010
Vinay Kumar
  • 438 Answers
SOURCE: Dell inspiron 1525 battery power light blinks
How old is the laptp? It seems that the battery has gone and needs a replacement. Please get a new one.
Posted on Feb 10, 2011
brian shevack
  • 902 Answers
SOURCE: My sharp fx cell phone went dead when I plugged it
try taking the battery out and plug it in will it turn on then?
Posted on Mar 26, 2011
Testimonial: "It worked thanks, I was then able to pt the battery back in and the phone is saying the battery is taking the charge. "
LF tracfone won't turn on
Take it to a phone sales location and see if they have new battery to fit .
Sep 26, 2015 | LG TracFone 600 Cell Phone - TF600GP4
Samsung Galaxy S model SPH-D700 won't turn on, how can I fix this?
To reset the phone, it should be without power at all. So removing the battery, when the charger is connected, will not reset the phone. Then when the battery is dead, it could show up as if it is charged, because the voltage on the voltage sensor can become high enough, to indicate the battery is charged.
First, disconnect the charger, and remove the battery. Wait a few seconds and reinsert the battery. Try switching the phone on. If nothing happens, the most likely thing is you have a bad battery.
I hope there is no other issue.
Success.
Apr 13, 2015 | Samsung Galaxy Cell Phones
My HTC hd2 phone went dead. When I switched it on
Hi ,
your phone need a software upgrade take it to a service center and upgrade the software if not working the mother board may be defective. only an authorised service center can help you.
Dec 07, 2017 | HTC Touch HD Smartphone
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Cell phone won't charge/or hold a charge
Jun 23, 2008 | Cell Phones
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
I went to go and charge my phone but it failed.
I have been made aware that the charging mechanism in the breaks off because it is made of plastic I was told it was a known problem but some stores will denie it and try to get you to you your insurance to get it replaced. For m that is a additional $50 charge and my phone is still under warranty.
Dec 08, 2006 | Audiovox CDM8910WW
Cell Phones Logo
23 people viewed this question
Top Galaxy Cell Phones Experts
A Kisling
A Kisling
Marvin
Marvin
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
