Question about Kenneth Cole Watches
Hi, I need a stem and a crown for my kenneth cole watch code: p93-12
6ya staff
SOURCE:
Anonymous
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
Anonymous
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
saturnd00d
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
How i set the date in a kenneth cole kc9225?
there two position to pull crown out
position 1 -- to change date
position 2 -- to change time
bring crown to position 1 and turn counterclockwise to set date on your watch. 9k=
Jun 10, 2014 | Kenneth Cole Swiss Chronograph Dial KS3018...
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
How do you set the time on a Kenneth Cole KC 1494?
According to the customer service rep at Kenneth Cole, You pull out the center stem to different degrees to adjust the various functions. Hope this is meaningful:)
Aug 22, 2010 | Watches
I can't seem to find the proper way to change the day and day of the week for the watch without manually spinning for a long time. today's Date: Sunday 25 but the Watch's Date: Monday 29
mcdevito 75 here, Most likely there are 2 positions in the stem (crown assembly) pull the stem out very carefully to it"s first position this should allow you to change the DATE either turning the crown toward you or away from you, once you get to the proper DATE, pull the stem out to it:s 2nd position, spin the hands until you get the proper day. Regards, Mike D 75
May 21, 2010 | Kenneth Cole KC1289 Watch for Men
Setting day/date on kenneth cole dual time watch I have a Kenneth COle KC1336 watch with analog hands, 2 digital displays, and it is also a stopwatch. Can't figure out how to change the day/date.
first, unscrew the stem lock. Then you can pull it out to the first "click". That is the "manual wind mode" if for some reason the auto-wind is not working due it has run all the way down. Pull it out again. That is the time set mode. The next "click" (pulling it out again) is the date set mode. Once you have them set, push the stem back in (past all clicks) and then re-screw the stem back to the lock position.
Aug 21, 2009 | Watches
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Watches Logo
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
