Question about Winchester Optics
What year is my winchester model 70 serial number G1217512
5 Suggested Answers
Adrian762
Adrian Ahrens
  • 425 Answers
SOURCE: 30-30 winchester lever action model number 94ae
Take it to a reputable gunsmith or Auction house, they will be able to advise you.
Posted on Feb 11, 2010
agent91
Ned White
  • 2100 Answers
SOURCE: When was my Winchester Model 94 Serial Number
Your mod 94 was made between 60 and 61, the The 1964 takeover reset all the serial numbers to 2, 500, 000. http://cowichanbay.net/winchesterguns/serial94.html
Posted on Feb 14, 2010
Matthew Salata
  • 4 Answers
SOURCE: wi want to know when my model 94 30-30 was made.
Winchester keeps an index of all serial numbers and manufacture dates. You can get this info off there website. You will need the model number and serial number, this will get you a year sometimes even a month if it a newer run. Good luck
Posted on Nov 26, 2011
roepke1
Austin Roepke
SOURCE: What is the torque specs for a Winchester Model 70
For HVB or custom pillar bedded stock, HS Precision recommends 65 in lbs. Other 3rd party stocks are 50 in lbs and Winchester recommends 35 in lbs in the post 64 manual.
And the #Gxxxxxxx rifles have unknown manufacturing dates. They were made by a company that never said what the year ranges were on the numbers.
Posted on Apr 12, 2012
SOURCE: When was Winchester Model 94 Serial Number 2057299 made?
1954
http://www.proofhouse.com/win/index.html
Posted on Apr 24, 2012
Winchester model 70 xtr 7mm mauser featherweight g1554069 what year mnufactured
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. Below is the download link for a special resource for ...
[PDF]Winchester Repeating Arms -- Date of Manufacture by Year -- Scans of ...
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-D... Winchester Firearms Manufacturing Dates by Serial Number and Year ... ASSIGNED TO GUNS AT THE END OF THE CALENDAR YEAR. 1866 -. 67 -. 68 -. 69 -. 70 - .... YEARS OF THIS MODEL AND IT WAS THEREFORE DlSCONTIN UED IN ...
What year was my Model 70 manufactured? - Winchester Repeating ...
www.winchesterguns.com/support/.../what-year-was-my-model-70-manufactured.htm... To obtain date of manufacture on a Model 70 made after 1992 please contact the Winchester Customer Service Department at 800-333-3288. In the event of alteration or the serial number being expunged, the BATF needs to be advised.
Date Your Model 70 and 94 - RifleShooter
www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803/ Nov 3, 2010 - Winchester's Model 70 bolt-action rifle is without a doubt, one of the ... rifle was made, the tables below show serial number range by year made ...
Model 70 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx70.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 70: Covering numbers: 1 - 1537135. Please enter a serial number and click the submit button.
May 21, 2018 | Winchester Optics
Winchester mod. 70 .308 serial G971249. Year of mfg. please ?
After 1992. Contact Winchester by phone at the number shown for information. Winchester Customer Service Department 800-333-3288
http://www.winchesterguns.com/support/faq/what-year-was-my-model-70-manufactured.html
Mar 18, 2018 | Winchester Optics
Purchased an older model Winchester model 70 at Cabelas and was told it was a super grade.Serial number is G1337707.can you confirm this?.
G`Day..Your Model 70
The year of manufacture for serial number 1337707 is 1977
I would check out this site for a rough value as it depends on Caliber etc..Good Luck... Pete
http://www.gunsinternational.com/guns-for-sale-online/rifles/winchester-rifles-model-70-super-grade.cfm?cat_id=1288
Apr 05, 2017 | Winchester Optics
Win 1894, s/n 857903, in 32-40. How common is this?
in 32-40 fairly unusual it would appear. Lots of information for you here.
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... totally accurate database of serial numbers from 1866 forward that we are aware of.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
totally accurate database of serial numbers from 1866 forward that we are aware of. ... 94 -. 95 -. 96 -. 97 -. 98 -. 99 -. MODEL 1866. 2. 12476 TO 14813. 15578 .... 32-. 1087836. 62-. 2551921. 03·. 291506. 33 -. 1089270. 63 -. 2586000. 04 - ... 40 -. 1142423. 70-. 3381299. 11-. 599263. 41 -. 1191307. 71-. 3557385. 12 -.
Winchester Model 94 - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .38-40 Winchester, and .44-40 Winchester, .410 shotgun, 30-30 caliber (30 WCF), ... began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ... Winchester 94 32-40 21 posts 13 Mar 2013 Original winchester model 1892?? 10 posts 19 Jul 2010 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Winchester 1894 date of manufacture. - Shooters Forum
https://www.shootersforum.com/winchester-94.../66444-winchester-1894-date-manuf...
  1. Cached
  2. Similar
Jun 22, 2010 - 5 posts It seems that date of manufacture numbers are probably off as much as two years in this time frame. .... Winchester's production of the Model 94 averaged about 35,000 units per .... 32-40 Rifle - serial number 692, 12-14-1894
Blue Book of Gun Values - WINCHESTER RIFLES: LEVER ACTIONS ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
WINCHESTER RIFLES: LEVER ACTIONS - 1860-1964 gun model and pricing information. ... lever latch, adj. sporting type rear leaf sight, serial numbers are in three digits only. ... .32-20 WCF, .38-40 WCF, or .44-40 WCF cal., iron frame with sideplates, .... 1940-1964 mfg. without saddle ring, barrel is marked Model 94.
Model 1894 ' Winchester Collector
winchestercollector.org/models/model-1894/
  1. Cached
  2. Similar
.32-40 - introduced in 1894 ... As serial numbers approached the one-million mark, the official model ... The Winchester Model 1894 Saddle Ring Carbine
Win 1894 857903 in 32 40 Google Search
Nov 15, 2016 | Computers & Internet
I got a win model 70 308 serial number 862911
You don't say, but I presume you want the date of manufacture?
http://oldguns.net/sn_php/winmods.htm
Other info for you.
  1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
  2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
  3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
  4. Related searches for win model 70 308 serials
  5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
  6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
  7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
  8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
  9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
  10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
  11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
  12. Pagination
May 24, 2016 | Optics
I got a win model 70 308 serial number 862911 whats this gun worth
Blue Book of Gun Values, plus what anyone is willing to pay. Condition is everything, especially condition of the bore. Taking it to a gun store is your best bet.
http://www.bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/...
Can you tell me the model of my 270 winchester rifle serial number is G1871685
This is more specific to decoding your serial number as the other information I gave was on your Model 70.
[PDF]Winchester Firearms Manufacturing Dates By www.winchesterguns.com/.../winchester.../serial-number.../Winchester-M...
  1. Cached
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. The following pages were scanned from documents ...
What year was my Winchester manufactured? (Serial ...
  1. Cached
  2. Similar
  1. Cached
  2. Similar
Dates ' Winchester Collector
winchestercollector.org/dates/
  1. Cached
  2. Similar
When was Your Winchester Made? ... Serial Number ... the dates of manufacture shown were obtained from the original Winchester Factory Polishing Room ...
Winchester Serial Numbers - ProofHouse.com
  1. Cached
  2. Similar
Main Page. Lever Action Rifles Slide Action Rifles Bolt Action Rifles Semi-Auto Rifles Shotguns Military Misc. Lever Action Rifles top. Walter Hunt's Repeater
Winchester Dates - ProofHouse.com
www.proofhouse.com/win/winchester.htm
  1. Cached
Serial numbers of the Henry rifle overlap those of the model 1866 from 1865 to 1866. .... George Watrous, a Winchester employee, counted total production at ...
  1. Cached
  2. Similar
Winchester Model 1894/94 Dates of Manufacture
www.savage99.com/winchester1894_dates.htm
  1. Cached
  2. Similar
Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
  1. Cached
  2. Similar
Nov 3, 2010 - We bought a Winchester model 70 with serial number G1741812. ... Kurt. Where can I find manufacture dates for Winchester Model 1894 rifles?
Winchester Model 1894/94 Factory Records - Shooters Forum
https://www.shootersforum.com/winchester.../67350-winchester-model-1...
  1. Cached
  2. Similar
Aug 12, 2010 - 7 posts It should now very clearly show the progression of verified dates of manufacture. I do not plan to add any additional new serial numbers to the ...
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
May 01, 2016 | Optics
I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? www.answers.com > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/.270_Winchester Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum https://www.shootersforum.com/.../31131-winchester-ranger-270-a.html
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... www.gunvaluesboard.com/what-is-the-value-of-a-winchester-model-70... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... www.proxibid.com > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE winchesterle.com/Products/handgun-ammunition/ranger/t-series/Pages/... Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board www.gunvaluesboard.com/winchester-ranger-m70-.270-win-8295726.html I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers www.answers.com > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... www.ableammo.com > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    When was my Winchester model 70 featherweight made? Serial number 35czy08232
    Nov 3, 2010 - Winchester's Model 70 bolt-action rifle is without a doubt, one of the ...what year was my winchester model 70 with serial number 511704 made? ....it&#039s a featherweight which suggests it wasn&#039t made before the ...
    Winchester Model 70 Featherweight - The Truth About Guns
    Jan 18, 2016 | Winchester Optics
    Optics Logo
    115 people viewed this question
    Top Winchester Optics Experts
    Colin Stickland
    Colin Stickland
    Fahr Quad
    Andrew Taylor
    Andrew Taylor
    Are you a Winchester Optic Expert? Answer questions, earn points and help others
