SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
SOURCE: Kitchen Aid Front Load Washer Model #KHWS01PMT1 flashes code DL
Your Door switch is faulty or, out of adjustment
SOURCE: Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
SOURCE: ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
