I have unplugged and plugged back in, no change. Have run copying function 2ce, but no change. Stymied.
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
SOURCE: scanner keeps saying USB not connected
Use the scan commands from the HP device manager, not the printer.
[email protected]
SOURCE: Problem with my HP 5510
Here is the solution link to your problem.
HP 5510 all-in-one "error; 0xf0af8004"
Good luck in correcting your problem.
SOURCE: clicking sound and in use/memory light flashes. Canon PIXMA MX850
I had this problem and found that I had plugged the usb cable into the wrong plug hole. I had tried a reinstall of teh printer which failed when it tried to recognise that teh printer was on and connected. When I moved the usb cable to teh correcr socket (closest to teh side of teh printer) it was fine.
Brian
