SOURCE: I have a hunter remote
There is no way. Only the manufacturer can reconfigure thw remote. That is part of the defect of this product.
If it works fine, leave it and just continue to use it.
Cheers.
SOURCE: F2 E6 on Whirlpool RBD305PDS14 double wall oven
Sometimes we see an intermittent electrical connection due to oxidation of the contacts on the keypad membrane tail. This can be easily cleaned so you can check this before investing in a new keypad. I posted some pictures and the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
SOURCE: ac/heater fan switch problem on a 2006 jeep commander
next to the fan motor there should be a connector that has three or four wires that attached to the blower resistor. it should have two screws holding it to heater case, just pull it out and replace.
Testimonial: "This info was very helpful but need a little more info of where the fan motor is located. I will post another question to find that info."
SOURCE: We have a Hunter ceiling fan with a remote
Hi.
Usually there are jumpers inside remote circuit and on IR sensor, by changing them you will exclude the possibility of IR interference.
IR is a light signal, therefore it is highly unlikely that the problem is coming from your neioghbors, the problem looks more like a defective IR sensor on the fan, that is not a too unusual fault.
I suggest calling Hunter Ceiling at the number listed on the owners manual to see what they think about the problem.
Regards.
SOURCE: POSSESSED MICROWAVE!
A microwave oven that is not grounded will sometimes behave this way. Make sure it is plugged into a grounded outlet, and that the outlet is actually grounded.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
