Question about Maytag Dryers
Hi, I have a Maytag sdg305daww dryer that will not stay on. When I push the start button, it tumbles - but, when I let go - it stops. Also, there is a slight burning smell, afterwards. I cleaned it out, greased the motor, replaced the door switch, and checked everything for continuity...... all seem good.
5 Suggested Answers
Anonymous
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
Anonymous
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
Anonymous
  • 550 Answers
SOURCE: MDE9606AYW Maytag Dryer
the start button activates a realy inside the control panel
the relay latches to supply heavy current to motor and heater, until door switch or timer switch break the latching circuit
If relay is on its last legs, it could be causing delay in starting, not closing secondary
the relay is represented by the dashed switches at the right of this maytag wiring diagram, note that it has no relevance to physical position of components
cc57668.jpg the relay in maytags looks like this
36631dd.jpg, but may be opaque, and mounted vertically (pic left is up)
Posted on Oct 08, 2008
John Hall
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Gas dryer, not heating up.
change the coils on valve / very common problem . they get hot after first burn then donot open again . you can ck this by watching the ign turn on it will get hot and when it goes out the burner should light but does not . . usualy after about 5 min ob run time .,.mm pls feed back .
Dec 17, 2009 | Washing Machines
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Hoover tumble dryer
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
83 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
