Samsung lcd monitor b2030
is the power LED actually dead?
is the screen 100% dead
is he front menu OSD button dead.
if yes, yes, yes, then the monitor is DEAD. of AC power is ok.
learn this fact all monitors before magic year 2010
are dead, due to CCFL back lamps burned out.
and will cost 2 times new, to fix it.
your manual shows year 2009
if it try to buy screen it shows me , the main board has 2 highvoltage CCFL lamp jacks.
so CCFL are dead. most are, most died in the year 2014
if run every day for 5 years, they GO DEAD.
or less if run 20 hrs /day.
if parked on shelf for 10 years, it works. see? 20,000 hours life spans.
best is to buy a 2011 and up monitor cheap even used.
with LED back lamps. and enjoy a long lived monitor.
CCFL jacks right side ! back lamps that love to die.
It have any led indicator light... if not check power cable if power cable is OK....then problem is in Power supply of monitor...it cant repair by you...
SOURCE: when i am on the computer the lcd monitor samsung
there are there are 3 approaches to this type of problem so the first ine is for you to check your Memory RAM if is OK by using another one to check your system
the second one is for you to check your computer with another monitor
the last one is for you to check your system VGA (visual graphic adapter) onboard or better still if u are getting confused you need to see a computer technician,
SOURCE: samsung 20" LCD monitor B2030
OSD Lock & Unlock Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Please leave rating if it helps.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
SOURCE: Is the Samsung B2030 LCD
Yes it is. it supports any recently built software because it was built to do so.
SOURCE: Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
