Question about Simpson Washing Machines
My machine fills up with water and when it is ready to start washing it makes a noise that it is slipping or ready to take off what shall I do simpson eziset 8.5 kg
6ya staff
SOURCE:
hattonhall
Poppa Maddo
  • 372 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
Tony Pike
  • 59 Answers
SOURCE: my simpson eziset 950 washing machine is leaking
OK the trasnsinssion will be full of water and the contents are being forced past the lower oil seal during agitation. You might enwuire about a new transmission or get a new machine....not the best news but if you went for a stronger make you could own it for twenty years......no joke. www.thewashingmachineman.webs.com ask tony
Posted on Sep 07, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Simpson eziset 550 washing machine makes a
It appears your clutch assembly or tub bearing has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
theredrage4
SOURCE: my Simpson eziset 800 washing machine will not
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Posted on Dec 18, 2010
theredrage4
SOURCE: I have a Simpson Eziset 550 washing machine and it
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Hello, My old simpson 175 goes fine upto the spray rinse and then makes this HORRIFIC screaming sound! As its so loud, I dont know if it is actually working but you HAVE to stop it. It sounds like...
Yes sounds like a dry bearing. Belt driven machines can also make a screeching noise if the belt slips. Spray with Belt Conditioner available from auto supply shops. Australian machines a bit problematic for this North American based site. I see manuals listed but nothing that looks like a schematic or workshop manual. There is a link to the Simpson website though.
https://www.simpson.com.au/other/contact-us/
[PDF]User Manual - Simpson https://www.simpson.com.au/globalassets/...manuals/sman_ezisensor_feb12_omo.pdf
  1. Cached
SWT801 and SWT951 Control Panel. Important Safety Instructions ii. 1. Water Saving Technology. 3. Knowing Your Washing Machine. 3. Washing Intructions. 4.
simpson 175 washing machine schematic Google Search
Aug 27, 2017 | Simpson Washing Machines
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
I have a Simpson Ezi Set 450 top loader washing machine which doing everything else although it will not agitate, why?
Fairly common issue. Motor control module is shot.
You can get them from your local parts shop, or ebay.
Sometimes they are direct swap by the big plug, sometimes there is slight rewiring required (wiring diagram comes in kit and they are just spade connectors on to the timer, no splicing or anything).
If you take the top panel off and it does not have a module exactly like in the pic on ebay, make sure you are happy to do the wiring bit before buying (easy if you can read a simple wiring diagram)
http://www.ebay.com.au/itm/0628271101-NEW-Simpson-Hoover-Reversing-Motor-Control-Module-GENUINE-/201054721557?pt=AU_ApplianceAccessoriesParts&hash=item2ecfcb9615&_uhb=1
May 26, 2014 | Simpson Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
My washing machine Simpson Model no 22S711 wont turn off when it is filling up with water
if it stops when you turn the machine off the problem will be that the pressure switch chamber is blocked unblock it should be ok
Sep 30, 2012 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
