Computers & Internet Logo
Frank Prete Posted on May 25, 2019
Owner manual My unit has symbols not words. I need to know which symbol is for dehumidify. It is a portable 10 -12000 btu unit. Thanks
5 Related Answers
Anonymous
  • Posted on Sep 04, 2007
SOURCE: PHILIPS DVP721 COMBO
You have pressed C.LOCK (child lock) which turns off the control buttons on the front of the unit Press C.LOCK again to switch off the child lock. OFF will appear in the display window. See: http://www.p4c.philips.com/files/d/dvp721vr_05/dvp721vr_05_dfu_eng.pdf
Anonymous
  • 837 Answers
  • Posted on Apr 07, 2009
SOURCE: Warning symbol for my 1997 Pontiac Gran Am
If you are interested I can also direct you to the proper website where you can download an owners manual for your 1997 Pontiac Grand Am
Anonymous
  • 83 Answers
  • Posted on Jun 03, 2009
SOURCE: I need to know the symbols on remote and what every symbol means?
The model number seems to be for a wall mount unit. here si the link for the manual:
http://www.pt.hu/application/document/download/1244055252_b2bec98a0010140ead0936e6ea9d75d6/JLA_LLA_PART_LIST.pdf
I hope this helps.
Anonymous
  • 62 Answers
  • Posted on Aug 24, 2009
SOURCE: CIRCLE SYMBOL with dashes around the outside what does this mean?
Brake pads
Have the brake pads checked
immediately.
dc39396.jpg For your own safety: use only
brake pads that BMW has
released for your particular vehicle
model. BMW cannot evaluate nonapproved
brake pads to determine if
they are suitable for use, and therefore
cannot ensure the operating safety of
the vehicle if they are installed.<
Testimonial: "Thank you so much. I guess i shouldnt be driving it around at all then until i get it fixed?"
Anonymous
  • 1986 Answers
  • Posted on Oct 21, 2009
SOURCE: need to know what the symbols mean on my dash lost
It's your oil light.
Check your oil light as it's most likely low. Other causes can be a bad sensor, or there's a pressure leak
What do the symbols on the remote mode mean
The symbols show pictures of the function provided for more specific answer send a list of symbols on your unit .
Thanks,
Alex
Forestair 9000 btu portable airconditioner Manual
Need free on line manual for a Araticpro air? need to know the symbols are!
The DeLonghi PACA130HPE 13000 BTU Portable Air Conditioner unit will not function. Unit displays the Alert symbol only and no other designation as identified in the product manual. The unit was in heat...
I had the same problem, you have to empty the water pan in the rear of the unit. In the heat mode it will NOT evaporate the water like in the air conditioner mode. If you use it a lot in the heat mode and have a lot of moisture in the house you will have to modify the water outlet to have it constantly draining in a pan or out of the house.
John
3helpful
2answers
I need a manuel for the danby dehumidifier model #DDR557HE. I dont know what the symbols mean
Unfortunately, the model number you listed has been discontinued. But is still supported thru the Danby Consumer help line: 800-263-2629. Contact them regarding your need for the Owner's Manual and they can email you one as an attachment.
I hope this helped you, Susan. Thanks for choosing FixYa.
1helpful
Can you explain the screen symbols
I can do better than that. Here's a link to the Owner's Manual, that you can download & print for future reference. See Page # 6 - Operating Instructions, for an explanation, as to what the symbols on the unit mean.
http://www.danby.com/cms/uploads/products/en_manual/DPAC_12099_EFOM.pdf
I hope this helps you and thanks for choosing FixYa.
2answers
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
When the unit comes on, it asks for a pass word
Default password for Symbol is: Symbol
I am a Barcode Tech let me know if this works otherwise I will look into this matter more for you
many thanks
Robert
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
