Question about Hoover Washing Machines
Hoover vision had washing machine how do I cancel timer saver machine washes but won’t spin and timer saver keeps flashing
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
Posted on Mar 16, 2009
Anonymous
SOURCE: time saver on my Hoover
my machine had the same fault and seems to be quite common. What I didwas remove the pcb behind the control panel buttons, its held on byseveral plastic clips and simply ensure the ribbin cable was making agood conection from this board to the programmer. My fault was either aloose connection or the pcb was not in the correct position either way,it now works perfect and only took 5 mins work @ no cost.
Posted on May 23, 2009
swatpakistan
  • 3 Answers
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
Posted on May 13, 2010
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hi i was wondering if you help.my hoover hd vision
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
Can't open the door timers saver & 1200 spin lights flash
There is a known problem with these washers whereby a small electrical current 'leak' from the heater element causes the machine to think it still has water in it.
Disconnect the wires on the heater (tape them up or otherwise make safe) then run a cycle to verify that part as the problem.
Jan 31, 2018 | Hoover H130E Front Load Washer
Time saver on my Hoover Hd Vision washing machine keeps coming on mid wash! Don't know how to cancel it.
Aug 30, 2008 | Washing Machines
Hoover vision hd 1400 washing machine not draining. Drum does spin. Time saver button flashing but not activated and if pressed does nothing.
Apr 15, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
