Does it occasionally. Today I went to leave, turned the key, click click click click. Waited a few minutes, did again. Tried again, it started right up.. No clue why...
Check the battery connections and make sure contact surfaces are clean and hardware is tight.Unless the starter or starter relay is going bad on you, 9 of ten times this will get you going again.
the manual covers this, the IMMO is active. ?
car will not crank, is that it? it must crank to start. so cranking is 1st.
you turn the key and the IMMO LAMP must NOT be showing its blocking starts. is it
do you have full batteryvoltage. 12.6v at the battery terminals I waited a few minutes and the dash board lights started coming
that means the battery is dead.
the dash waring lights must come on ,at key on, fast
if not we fix that first. that means power lost, 12vdc power loss.
use a voltmeter. at battery
I would start with checking the computer for trouble codes. Sounds like a bad connection in the dash wiring or key switch, but the trouble code might steer you in the right direction.
YOUR WIRELESS CONTROL MODULE(SENTRY KEY MODULE)MAY BE ELECTRICALLY LOCKED UP..THERE IS A SERVICE BULLETIN FROM CHRYSLER..YOU CAN REMOVE IOD FUSE IN FUSEBLOCK(UNDERHOOD BEHIND AIR CLEANER..IGNITION OFF DRAW(IOD)THIS WILL RESET WIRELESS CONTROL MODULE AND VEHICLE SHOULD START AND LOCKS RESPOND AGAIN..IF IT DOES,THE WCM WILL HAVE TO BE REPLACED AND THIS NEEDS TO BE DONE BY DEALER
What happens when you turn the key?... is there a clicking or clunking noise?... try tapping the starter and the solenoid that is attached to the starter and see if that helps. It may help if you have someone else turn the key while you tap on the starter and solenoid.
