Any numbers on the car's VIN are related to factory fitted equipment only. To receive Sirius Satellite Radio on the NX501, you can connect the optional SC-C1 Sirius Connect Universal Vehicle Tuner 607SCC1 directly to the head unit's Sirius direct connection (no proprietary interface required), although this is no longer available, or try https://www.sonicelectronix.com/item_91789_SiriusXM-SXV300v1-70-Rebate-3-Months-FREE.html
SOURCE: Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
SOURCE: Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
SOURCE: I have clarion xmd1 in my new boat
yes you can hook up xm to it, but you have to have the xm reciever and interface to hook up to it
SOURCE: 2006 vw jetta gli sat radio, sirius expired, now want xm
U can't change the provider, the radio's are built to recieve sirius or xm, u can't have both on the same radio.
SOURCE: sirius/xm activation
Typical, they wont recognize sirius and xm on the same account. tyou need to close the old account and open a new account on the new brand head and start from square one. Also - they wont give multi head discounts if you have a mix of siruis branded heads and xm branded heads - each brand needs its own account and own e-mail address. They **** in this regard. Good luck, ive decided between this backwards book keeping and aneed to keep resetting my Sirius head periodicaly that neither is worth the aggrivation so I cancelled all of them.
