If it is rps that needs replaced how can I check, or if it is the board that needs replaced how can I check ?
Https://www.searspartsdirect.com/washer-repair/error-codes/whirlpool-cabrio-top-load-washer-error-codes.html
Motor Stalled
The motor RPS (Rotor Position Sensor) detects no rotation of the drive motor. Unplug the washer. Check to see if the basket spins freely. If not, then examine the drive system and eliminate the cause of friction. If the basket spins freely, check the wire harness connections between the main electronic control board and the motor. If the wire harness connections are okay, check the drive motor. If the motor is defective, replace it.
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
SOURCE: Cabrio won't spin
F then 50 flashes when the motor rotor
position sensor (RPS) senses no rotation.
➔ Does basket turn freely? If not, make sure
bottom shipping pack has been removed.
Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control,
by analyzing drag on the basket, detects a
suds-lock condition, and is steady on while the
control then runs a mini-clean out cycle. If the
clean out cycle is unable to correct the
over-sudsing problem, the cycle ends and Sd
flashes in the display. This may signify:
➔ Load is bunched or twisted around agitator.
➔ Excessive detergent usage.
➔ Basket cannot engage during drain step.
➔ Mechanical friction on drive mechanism,
not allowing basket to engage.
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
SOURCE: Silverdragon posted on here about the Whirlpool
Tip mch back and locate the lg allen bolt in the center of the magnet and remove counterclokwise. The motor is actually a large magnet that revolve around a stator, a series of windings. Pull hard and place magnet away from any metal. Once off, remove the bolts holding the stator to the base and on the reverse side is the rps sensor. It looks like a wedge and is clipped onto the stator.
