Question about Toshiba Televison & Video
Toshiba sd1015kb after insert ink disc it states loading but then states disc dirty. The disc is new, other disc are the same.
Dirty lens or weak optics
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 293 Answers
SOURCE: Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Posted on Sep 21, 2007
Andrej.cet
  • 338 Answers
SOURCE: Toshiba Recovery Disc Creator isn't working
hello lazerr_man,
Try to use another freeware burnprogram like burnatonce to create an
other CD, just to check if the Combo-drive is writing properly.
If you don't get any error messages like the ones from Toshiba program, then the problem is the toshiba software.
If other burn programs find difficulties in accessing CDs or DVD-Rs
then the drive itself giving you a hard time and might seek for replacement.
You may find the toshiba exchange parts too expensive and the internal drive is still reading disks properly, then think about an external dvd-rw drive, but make sure to buy a highspeed USB one (or even firewire, if the laptop has the port), else it will run rather slowly.
good luck
Posted on Sep 07, 2009
SOURCE: i have an issue with my ps3 slim 250 gb, when i
Sounds like you have an issue with the blu ray drive itself. This is actually a more common problem with PS3 than many people know. Do not try to fix this yourself as it will void you warranty. Contact Sony as it should still be under warranty and you will need to ship it away and get it fixed.
Posted on May 19, 2011
Multi region hack code for toshiba SD1015KB
the same code for making the Toshiba SD1010 will work on the SD1015KB
1) Turn on the dvd player
2) Press the eject/stop button on the dvd player (not the remote) to open the tray, and leave it open!
3) On the remote press 98790 (if done right, a message will appear stating that region has been changed to 0)
4) Done
Jan 28, 2013 | Televison & Video
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
The dvd player just says it is loading and never plays the disk
The reason your player keeps reading a disc but do not play it is either the lens is weak or dirty.
To fix it if it is dirty, all you have to do is to clean the lens with a lens cleaner.
To fix it, if the lens is weak,
  1. Get the appropriate screwdriver,
  2. Unscrew the cover of the player and remove it,
  3. Unscrew the disc tray, you will have access to the lens,
  4. Get a new lens and replace the lens,
  5. Reverse the process to reassemble the player.
  6. Test it with a DVD disc.
Take care
Jun 20, 2010 | Memorex MVD201 DVD Player
When I insert a dvd it start to load then it say No Disk
The lens from the reading head is dirty to clean it you go 2 ways;
1  - easy one - not always efficient: use one of those special cleaning disks.
2 - hard way - most chances of success: remove the case and access the mechanism, use a can of compressed air to blow away all the loose dirt (be thorough especially under the lens) then use a q-tip to gently wipe the lens.
Jun 15, 2010 | Mintek DVD-1600 DVD Player
Discs will not play. After loading for about 1 minute no disc note comes up. Discs have been cleaned and neither dvds or neo discs play.
The reason the player wont play the disc is either because the lens is weak or dirty.
Try to clean the lens with a lens cleaner and test with a DVD disc.
If it does not work, then it means the lens is weak and needs replacement.
To replace the lens, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care.
Jun 15, 2010 | Televison & Video
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
Disc error
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play DVDs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Toshiba SD-2815 Multi-disc DVD Player
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
Televison & Video Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
