SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
SOURCE: NEED MANUAL FOR SAMSUNG MODEL LNT 1953H LCD 19''
..review of the product and related issues:
http://www.amazon.com/review/R2LL7LEO1ABLU8
Crutchfield's take on that model and it 'ease of use issues':
http://www.crutchfield.com/S-rsaLPNJLHDO/p_305LNT1953/Samsung-LN-T1953H.html
..more specifications from that site + related comments:
http://www.crutchfield.com/p_305LNT1953/Samsung-LN-T1953H.html?tp=161&tab=detailed_info
...manual download page for 19" LCD series:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=LN19B360C5D
Rule of thumb is check a similar product in case you can't find exactly what you want. Discussions on those other sites indicate they only have "user guides" for the LNT 1953H LCD 19" ..and nothing in the way
of serious service manuals (i.e. for the consumer).
Email me back for more info:
[email protected]
SOURCE: samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
This is caused by bad capacitors in the power supply board. If you are off warranty, you can fix it yourself at home with kits available at www.karmtec.com.
Link to the kit for that TV
http://www.karmtec.com/Products/Samsung-LNT4665FX-XAA-Power-Supply-Repair-Kit-122.html
SOURCE: I have a dynex remote control that I need to use on a zenith TV. Can you give me the codes?
Codes to check with Zenith TVs are: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
