Jeff Travis Posted on May 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where and how do I register Altec Lansing MZX300 Bluetooth over-ear headphones ???
Mai Lor
Level 3:
Genius:
  • Altec Lansing Master 2,558 Answers
  • Posted on May 28, 2019
Mai Lor
Level 3:
Genius:
Answers
2558
Questions
0
Helped
524462
Points
7053
-Read its owner manual.
Good luck
Mai
5 Related Answers
Anonymous
  • 277 Answers
  • Posted on Mar 21, 2006
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Anonymous
  • 171 Answers
  • Posted on Sep 24, 2008
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Anonymous
  • Posted on Nov 20, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Vj24601
  • 4 Answers
  • Posted on Dec 04, 2008
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Anonymous
  • 7 Answers
  • Posted on Apr 22, 2012
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Left side no sound
Check the device with another pair of headphones if you have them.
Make sure your balance control is in the middle.
Make sure the plug is all the way in.
Wiggle the cord to try to find an open in the wire.
If you've checked all and there is still no sound on the left, I would say an open in the wire somewhere is the culprit. If they aren't old, perhaps you could contact Altec Lansing for a warranty repair or replacement? You may be pleasantly surprised at their customer service, if you're nice, and patient.
1helpful
2answers
I don't know how to use the blue tooth on my altec wireless headphones
YOU SHOULD BE ABLE TO GO TO YOUR BLUETOOTH ON YOUR PHONE AND SEARCH FROM THERE . IT SHOULD FIND YOUR HEADPHONES.
I have a set of 4 Altec Lansing surround sound speakers with a subwoofer i bought in 2003 with my dell computer. I can't get any sound from them. Do you have any suggestions? I tried hooking the system up...
If you are listening through headphones that are plugged in to the Altec system, then your problem is the amplifier is bad. Can't help you online with that. Sorry!
2answers
Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
20helpful
2answers
Backbeat 903 I tried to pair them but they don't with my g1
1. turn off the headphones
2. turn on bluetooth on g1
3. hold down the power button on headphones until u see the red and green light flash back and forth. (may take 8 seconds or so)
4 search for devices on g1
5. pair them. if it ask for code it... 0000 (4 zeros)
2answers
Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
