OPPLE CDO Posted on May 29, 2019
My printer has red light cant print. pls help
4 Related Answers
Anonymous
  • Posted on Apr 26, 2008
SOURCE: LIGHT FLASSING CANT PRINT
Brother-2040 printer has all lights flashing at one time. How do you fix it?
Anonymous
  • 284 Answers
  • Posted on Dec 09, 2008
SOURCE: Pansonic DP 8016
sounds like you need to have a PM done to the machine. there is a PM counter and when it reaches the 120K it will stop till you have a tech clean it and replace parts ans reset the counter
Anonymous
  • 541 Answers
  • Posted on Jan 27, 2009
SOURCE: EPSON R230 PRINTER IN INDIA BOTH RED LIGHT FLASING. PLS HELP ME
hold down all 3 bottons to reset it or download the ssc
Anonymous
  • 3 Answers
  • Posted on Feb 07, 2009
SOURCE: help
You can probably access the back of the printer to see if there is paper jammed there and remove it if there is.Normally there is an indication as to which ink cartridge needs replacing On some printers when one opens the cover the print head will move to a point which will indicate which cartridge needs replacing..
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
10helpful
5answers
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
14helpful
1helpful
Stopped printing
I am guessing that the toner waste container needs to be emptied (you can do it your self) and/or the sensor is acting up.
http://www.fixyourownprinter.com/forums/laser/34677
from sean6969
waste container has to be perfectly clean to reset the sensor - water only will make it smear - must use dish soap to cut the black toner smudges... let it dry fully. (this had happened to my printer)
1helpful
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
The lights are still blinking..i cant even let the cartridges out..theyre stuck If i restart the printer, same problem occur
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. I have a red bullit on it for you to see.
If you find this helpful pls rate me.
Thanks and Good Luck.
5helpful
2answers
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
51helpful
6answers
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
8helpful
7answers
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Top Light Office Equipment & Supplies Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
