SIYABONGA MAZIBUKO Posted on May 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix error200 - Office Equipment & Supplies
Fahr Quad
Level 3:
  • Master 776 Answers
  • Posted on May 30, 2019
 Fahr Quad
Master
Level 3:
Answers
776
Questions
0
Helped
310443
Points
2299
What piece of equipment is displaying that error code?
2answers
How to fix Norton VPN not Working?
Users complain of encountering issues while using Norton. If you are facing Norton VPN Not Working, then this blog is here to help you.
How do I Fix Norton Secure VPN if it Stopped Working?
Fix 1: Inspect Your Internet Connection to Fix Norton VPN Not Working
Fix 2: Change Firewall Settings
Fix 3: Update Norton
Fix 4: Modify Your DNS Settings
Fix 5: Use Another Server
Fix 6: Reinstall the WAN Miniport Drivers
Fix 7: Refresh the Network
Fix 8: Examine the Root Certificates of Norton Secure VPN
So here were the steps to fix Norton VPN Not Working issue. In case of any existing issues, feel free to contact Norton customer support.
How to Fix 0xc004c060 Windows 10?
Windows 10 Error Code 0xc004c060: Fix This Activation Error With Easy Workarounds
  1. Fix 1: Use the Windows Activation Troubleshooter Tool.
  2. Fix 2: Set the Windows to Update Automatically.
  3. Fix 3: Change the Activation ***********.
  4. Fix 4: Delete the Temporary Files.
  5. Fix 5: Turn Off the Proxy Settings.
https://getsolved.org/fix-windows-10-error-code-0xc004c060/
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
CANON PIXMA 372
seems to be obstruction or print head fault go to cannon uk web page for technical assistance
3answers
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
What is city area code of doha qatar
hello;
select your place codes with sub codes: 974284250 9741121127 XES Emergency Services 974124522094 XVM Voice Mail & SMS 97421738223 PAG Paging 9742244520 PAG Paging 974286 Fix Line MATS 9744137128 Fix Line MATS 9744289375 Fix Line MATS 9744341613 Fix Line MATS 97443041613 Fix Line Doha Central (DC3) 97443141613 Fix Line Doha Central (DC1) 97443241613 Fix Line Doha Central (DC2) 97443341613 Fix Line Doha Central (DC1) 97443441613 Fix Line Doha Central (DC2) 97443541613 Fix Line Doha Central (DC3) 97443641613 Fix Line Doha Central (DC2) 97443741613 Fix Line Doha Central (DC3) 97443841613 Fix Line Doha Central (DC3) 97444563138 Fix Line MATS 974440563138 Fix Line Doha Central (DC3) 974441563138 Fix Line Doha Central (DC1) 974442563138 Fix Line Doha Central (DC2) 974443563138 Fix Line Doha Central (DC1) 9744431599563138 Fix Line PSTN Testnummer 9744432599563138 Fix Line PSTN Testnummer 974444563138 Fix Line Doha Central (DC2) 974445563138 Fix Line Doha Central (DC1) 974446563138 Fix Line Industrial (IEC) 974447563138 Fix Line Doha Central (DC2) 974449563138 Fix Line Doha Central (DC1) 9744546098 Fix Line MATS 97446196683 Fix Line MATS 974460196683 Fix Line Industrial (IEC) 974461196683 Fix Line Industrial (IEC) 974462196683 Fix Line Airport (APC) 974463196683 Fix Line Rayyan (RYC) 974464196683 Fix Line Wakrah (WKSC) 974465196683 Fix Line Airport (APC) 974466196683 Fix Line Airport (APC) 974467196683 Fix Line Airport (APC) 974468196683 Fix Line Industrial (IEC) 974469196683 Fix Line Industrial (IEC) 97447252915 Fix Line MATS 974471252915 Fix Line Rayyan (RYC) 974472252915 Fix Line Khuratiyat (KRC) 974473252915 Fix Line Doha Central (DC3) 974474252915 Fix Line Doha Central (DC1) 974475252915 Fix Line West Bay (WBC) 974477252915 Fix Line Wakrah (WKSC) 974478252915 Fix Line Khuratiyat (KRC) 974479252915 Fix Line Khuratiyat (KRC) 974482826 Fix Line MATS 9744802826 Fix Line Rayyan (RYC) 9744812826 Fix Line Rayyan (RYC) 9744822826 Fix Line Rayyan (RYC) 9744832826 Fix Line West Bay (WBC) 9744852826 Fix Line Doha Central (DC1) 9744862826 Fix Line Khalifa Town (KTC) 9744872826 Fix Line Khalifa Town (KTC) 9744882826 Fix Line Khalifa Town (KTC) 9744892826 Fix Line Khalifa Town (KTC) 9744955072 Fix Line MATS 974507311 Mobile Mobile GSM 9745211796 Mobile Mobile GSM 97453192116 Mobile Mobile GSM 9745416281 Mobile Mobile GSM 97455548189 Mobile Mobile GSM 9745620766 Mobile Mobile GSM 9745825251 Mobile Mobile GSM 974593 Fix Line Fixed Telephone Cellular 97459383 Mobile Mobile GSM 97459393 Mobile Mobile GSM 97490097012 XAT Audio text Services
1helpful
I forgot my blackberry 8520 pin code to fix error200 what shal i do pls help
Hello
Ok, if you are talking about the phone security code which was usually asked when the phone has been restarted, here is how we fix this.
You will need to enter in the wrong code until you are prompted to enter the PUK code. Click HERE to read how retrieve the PUK code.
Let me know if i understood the question.
Kind regards
Andrea
I have canon ir 5800cn error 014 please any help
There is service bulletin that says:
Measures against noise, E014, and faulty fixing caused by coming off of fixing roller
Detail:
<Symptom>
The fixing roller comes off, leading to noise, E014, and faulty fixing.
<Cause>
Because the fixing spacer [2] does not rotate while the fixing roller [3] is rotating, the retaining ring [1] becomes
detached due to frictional resistance with the fixing spacer, and the fixing roller comes off as a result.
<Factory Measures>
A projection (P-2 [1]) is added to the fixing spacer. When attaching the fixing spacer, fit the projection in a
groove (P-3 [2]) of the fixing roller shaft so that the fixing spacer will rotate together with the fixing roller and
frictional resistance between the fixing spacer and the retaining ring will be eliminated. Therefore, the retaining
ring is prevented from becoming detached.
Service Work:
Replace the fixing spacer with the new-type fixing spacer when the foregoing symptom has occurred in the
field.
To prevent occurrence of the symptom, check the shape of the fixing spacer when replacing the fixing roller,
and replace with the new-type fixing spacer if the previous-type fixing spacer is attached.
<Point to note on attaching the fixing spacer>
Fit the projection (P-2 [1]) in the groove (P-3 [2]) of the fixing roller shaft to attach the fixing spacer.
OLD SPACER, FIXING FC5-2590-000
NEW SPACER, FIXING FC5-2590-020
Affected Machines:
iR C6800 EUR 230V JKH01022 and later
iR C6800N EUR 230V JKP02113 and later
iR C5800 EUR 230V KEN00106 and later
iR C5800N EUR 230V KES00135 and later
This is factory error, and I think that you must call service and have it fixed under warranty.
Hope that helped
k24674
ADMIN Andrew
ADMIN Andrew
