SOURCE: I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
SOURCE: Zebra SM4 label printer to change ZPL to EPL
You will need to change the firmware on this printer in order to be able to change the language. I don't believe this printer will allow you to change the language using the advanced options in the menu unless they have recently changed this.
Here is a link to the manual where it tells you where you can download the firmware for the printer and how to install it. It is pretty easy but if you have any problems, please get back to me and i will point you in the right direction.
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
SOURCE: zebra zm400
check the size of the document and the Zebra Fonts;
Install Zebra font if not install and its resolv
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
