Some suggestions that I have had was to adjust the vertical voltage setting on the power supply ? Assuming that I can find that.
SOURCE: Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
SOURCE: KF-42WE610 blue dots and blue vertical haize
Go to the Sony Web support site. If your TV is one of the models listed with the blue dot problem (there are pictures of what the screen looks like with this problem)on the site, Sony is now saying that they will cover the cost of the part and the repair. We did what I'm suggesting and are having our part put in today. Sony decided this was their responsibility for some models of their LCD big screen HD TVs in June of this year. We were contemplating an estimated repair bill of over $1000 until we found out they were taking responsibility for this problem. Good luck, I'm not a truly techy person, but hope I have pointed you in the right direction. We have been living with blue people, etc. for about a year now, feeling angry about spending so much for a TV and it going bad so quickly. Hope this spares you that. You have only so much time to take advantage of this repair offer...
SOURCE: printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
SOURCE: tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
The Y sustain board is needs to be replaced.
Thanks, so there is no simple adjustment that will work ?
