SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
SOURCE: Brand new Reebok v6.80 treadmill, trouble on start up!
I just had the same thing happen to me with the same treadmill. I called Reebok and they had me remove the motor hood. Sure enough, the bolts holding the motor had completely sheared off and the motor was lying loose in the bottom of the treadmill. They are sending a new motor and bolts and a technician to install them. They said it was probably dropped hard during shipping.
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
