SOURCE: airgap spills over onto sink every time we run the dishwashers
Hi Jose31,
I'm Harvey the Master Plumber.
Your question is: Kenmore Elite dishwasher.airgap spills over onto sink every time we run the dishwashers. what to do?
This is very common! In most states the airgap is no longer required for this very reason. It's one of those ideas that looked good on paper. In my state I remove it. If you have to keep it, thats OK. All is not lost. The real culprit is crud buildup in the airgap discharge tube. You would have to remove it and clean it and the fittings. And next year do it again. May not be as simple as it sounds. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: After top drawer is run, bottom drawer has
check the check valve on bottom drawer. unplug hose drain hose off drawer underneath. a small ruber check valve can be clogged. if its good replace it
