I have tried every button but nothing will release the error and get it started again. Is there any way to reset the computer?
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
SOURCE: Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
SOURCE: error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT
YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
