Lands Phones Logo
M
Mark Elliott Posted on Jun 02, 2019
How do i tranfer external calls on the Uniden 1735-2. (I know how to internally transfer, just wish to tranfer to another externel number).
T Tatro
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Jun 19, 2019
T Tatro
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
20
Questions
0
Helped
4555
Points
38
I don't think you can transfer to external. You can make a 3 way call, but then you would have to stay on the line to keep that line open.
5 Related Answers
Harisk Karameh
  • 68 Answers
  • Posted on Feb 23, 2009
SOURCE: Transferring Calls
press transfer button
call the transfer extension
wait until the person picks up
tell who is calling
hang-up to finish transfer process
Anonymous
  • Posted on May 05, 2009
SOURCE: Transferring a call to a mobile
I was quite rude to the IT guy and it made him look into the problem for me properly and now the function works....this is after he told me for two weeks that it can't be done!! Bloody IT guys swallow your pride and ask for help if u need it!!!
Anonymous
  • Posted on Jul 09, 2009
SOURCE: I cannot transfer pictures from the internal
degital camera casio EXILIM EX-Z50
consultel1
george peters
  • 860 Answers
  • Posted on Jun 30, 2010
SOURCE: How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Anonymous
  • Posted on Oct 08, 2010
SOURCE: M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
How do we program answering machine on dect 1735 cordless phone
Do you mean the Uniden DECT 1735? You can turn on the answering system from the base On/Off button. The rest takes the hanset or a call into the phone. Start with the phone in standby (no handsets in use). Press Menu on a handset. Use the Up/Down arrows to navigate to Answering Setup and press Menu again. To set the number of rings, navigate to Ring Time and press Menu again. Use the arrows to select a number of rings and press Menu to save. Press the Left arrow/Page key to go up to the Answering Setup menu. Press End to exit the menu system.
To set the greeting, you would navigate to Record Greeting in the Answering Setup menu. Press Menu. When you hear "Record Greeting", speak your message. Press Menu when you finish. Press End to save the message after you hear it repeated. Press Menu and wait for the "Record Greeting" prompt if you need to change the greeting.
The manual for this is available on the product site: https://www.uniden.com.au/product/dect-1735-2/. The direct link to the manual is currently https://www.uniden.com.au/wp-content/uploads/2017/06/DECT_17352_OM.pdf . See the section starting on page 20 for the different steps to set up the answering system.
I hope this helps.
I would like to know how to transfer a call from one phone to the other on a cordless versatis p100
During an external call:
1. Press <MENU> and <UP/DOWN> to select INTERCOM.
2. Press <OK> to select the desired handset to intercom with.
3. The external call is put on hold automatically and the called handset
rings.
4. Press <TALK ON> on the called handset to establish an internal call.
5. Press <TALK OFF> on the calling handset or put the calling handset on the charging cradle to end the current call with the external party.
6. The external call is transferred to the called handset.
I have KX-T7030, how do i transfer the call to other numbers?
Hi Colleen When you say transfer calls to ther numbers do you mean to transfer one external number to another external number or numbers within the office?
Let me know will explain.
Speak Soon
Phil
How to transfer
While your on the line with the caller, press the Transfr button(above the hold key) then enter in the intercom number of the person you wish to transfer the caller to. You can either wait for the person your transfering the call to to answer his extension before you tranfer the call or you can hang up after you enter the intercom number, either way, when you hang up the phone after entering in the intercom number, the call is transfered to the extension.
3helpful
2answers
1helpful
Is it cheaper to buy an external burner or fix the internal one
yes buy an externel burner , you can use it also into another PC you want...flexible use..
I have no manual for the uniden 6.0 cordless phone and need to know how to transfer calls to another phone and then back again if need be.
No worry. Here is the link to all Uniden Dect phones. Select your model number and download the manual. You will need it to set up the call transfer.
How to use the to transfer phone calls
Call transfer on Norstar phones works by:
  1. Answer call
  2. Press the [Feature] [7] [0] (or simply press the [Transfer] button below phone display)
  3. Dial the number where you want to transfer the call
  4. Stay on line if wishing to speak to the person
  5. Press the [Rls] button to complete the transfer
  • If an external call is transferred to a busy internal or network extension, or is not answered after a few rings, the call automatically rings you back.
  • Note: Use Link to transfer callers to a telephone number
2helpful
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
rings you back.
Photos stored in Memory vs. Sim Card
Check the Camera Manual
The usual way is to put card in and using the menual tranfer from internal to card.
The computer should also pick up the camera as an external drive.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
