Washing Machines Logo
Lola Stewart Posted on Jun 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant find filtet its not drain Hotpoint Aquarius 900
Jimmy
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Jun 04, 2019
 Jimmy
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
32312
Points
154
Hi Lola, if you can't find a visible filter access, then you will have to tilt the machine backwards and you should be able to see the pump that way. It may not have a filter at all and the sump hose would need to be removed to gain access to any obstruction from tub to pump. If there's nothing blocking the pump then you most likely have a bad drain pump. I suggest calling a local repair company if you don't feel comfortable tackling this problem yourself. Hope that helps.
5 Related Answers
Paul Davies
  • 157 Answers
  • Posted on Dec 19, 2008
SOURCE: wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 21, 2008
SOURCE: hotpoint aquarius WMA58 spinning but
Suggest you check pump filter.
you will find it located at the rear right side of the m/c.
Remove lower rear panel, there you will see a large black hose, remove securing clip, and detach hose, the filter is located inside, remove and clean, make sure you put everything back in the same order you took it off.
This should solve your prob. Make sure the drain hose is not clogged and the outlet is clear also.
Plz rate my solution.
Thanks.
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Oct 06, 2009
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
active209
active active
  • 14 Answers
  • Posted on Nov 06, 2009
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Anonymous
  • Posted on Jun 15, 2010
SOURCE: hotpoint aquarius extra wma40 wont drain
hi it will not drain
I have bought a hotpoint washer dryer but with no instructions and i cant get the water to drain out can u help please ?
Remove rear cover of washer.
Locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Should there be a ball in the drain hotpoint
yes the ball should be in there,but shouldnt cause you any major problems if removed.
5helpful
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
18helpful
Where is the filter on the Hotpoint Aquarius washing machine?
Filtet access at the rear of the machine behind access panel, Remeber to remove the plug from the socket before removing the rear panel
2helpful
Wont drain water
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
2answers
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
3helpful
2answers
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Top Washing Machines Experts
john h
