The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time. 2. Menu window will show "OKI USER" 3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button. 4. "Diagnostic Mode xx.xx.xx S-Mode is indicated. 5. Scroll to "NV-Ram initial" is indicated. Push ENTER. 6. Window shows "NV-Ram- Initial Table 1". 7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window. 8. Restart printer.
What os are your using? XP, Vista, Win 7?) Also, was this a new motherboard and what type of case are you using? Lastly, I would recommend you checking your BIOS and make sure there are no limits set on the memory cap. (Usually found in older system but check anyway.)
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state.
RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
