Question about Simpson Washing Machines
Hi ,I had a simpson 7.5kg eziset. Problem is its on and the machine start but not regularly and it stops and I have to switch to the next cycle manually.but it's a automatic washing machine
    Master:
  • Simpson Master
  • 745 Answers
Do you have it set on heavy duty wash ? as it will stop and do a soak before starting again
Posted on Jun 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
hattonhall
Poppa Maddo
  • 372 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
Anonymous
SOURCE: Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Posted on Jan 23, 2010
luisa_sgro
  • 713 Answers
SOURCE: Hi I have a simpson eziset 605 washing machine and
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Posted on Oct 03, 2010
john_cross
  • 6277 Answers
SOURCE: Looking or a service manual
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply schematics only to service engineers but good luck anyway.
John C.
Posted on Mar 21, 2011
Hello, hope you can help, I have a eziset 550 simpson when I put the water on it starts filling but won't stop I have to listen & try to change settings so the water that won't stop running doesn't...
there is a small hose from the bottom of the tub to the water level switch
that gets air pressure to activate a switch when the level selected overcomes the switch spring
At that point the water solenoid is turned off and the wash cycle begins
over flowing indicates that the level sensor is not working or the inlet solenoid and diaphragm is faulty
if it doesn't progress the wash cycle , that indicates a program board problem so call the technician for a proper diagnosis
Sep 13, 2017 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Oct 03, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Washing Machines Logo
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
