Televison & Video Logo
A
Anonymous Posted on Jun 03, 2019
I have Toshiba android TV model 40L5450EE and I can't recall the password please help
matt
Level 3:
  • Toshiba Master 1,666 Answers
  • Posted on Jun 03, 2019
matt
Toshiba Master
Level 3:
Answers
1666
Questions
Helped
696233
Points
9998
tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 • Televison & Video
tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
tip
Toshiba 50HP95 Input Lock Reset
Toshiba 50HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
I hope that helps.
tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
I hope that helps.
tip
I hope that helps.
tip
I hope that helps.
tip
I hope that helps.
tip
I hope that helps.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
