Televison & Video Logo
Marsha Graf Posted on Jun 03, 2019
Put all new parts in Samsung tv and still blinks 5xs and shuts off got kit and replaced everything but speakers then replaced the 3 led strips no pic no sound turn on blinks 5x 's and shuts off
5 Related Answers
Anonymous
  • Posted on Sep 10, 2008
SOURCE: haier 42hp25bat no pic and sound
solo se ven lines en colores noda mas
TONY BIGNELL
  • 147 Answers
  • Posted on May 26, 2009
SOURCE: turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
Anonymous
  • 16 Answers
  • Posted on Dec 03, 2009
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Anonymous
  • Posted on Aug 29, 2010
SOURCE: my tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Anonymous
  • 20 Answers
  • Posted on Aug 12, 2011
SOURCE: PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
1helpful
Hisense 50H6570G indicator continuously blinking doesn't turn on. Replaced Powerboard, TCON and WiFi board. What could be the problem?
First thing to do is put the original boards back in the TV, none are bad, you have defective LED strips in the panel, real common issue with this model set, the power supply inverter senses the over current and shuts down, you get the blinking standy light when this happens
Do you know a place that sells ONE Samsung BN96-45954a edge lit led strip bar.
Shop Jimmy for all parts. You need to change all the LED strips. If you don't, the difference in light intensity and colour will drive you insane!
ShopJimmyâ„¢ Official Site - The Online Leader In TV Repair
Ad·https://www.shopjimmy.com/
The Online Leader In TV Repair And Replacement Parts. Check Out Our Huge Inventory Today! Shop Online And Check Out Our Huge Inventory Today Of TV And Appliance Parts Today! 180 Day Warranty. Servicing All TV Brands. Repair Kits Available.
"); background-size: 13px 15px; background-repeat: repeat-x; font-size: 0px; line-height: 0;">") 0px 0px / 13px 15px repeat-x; line-height: 0;"> Rating for shopjimmy.com: 4.5 - 344 reviews
TV PartsTV Boards, Cables, Lamps, Remotes,
Speakers, Stands, Tools, And More!
TV ComponentsScrews, Capacitors, Diodes, Fuses,
ICs, Resistors & More TV Components
Appliance PartsShop Parts For All Appliances Such
As Fridges, Dryers, Stoves & More!
TV Stands & MountsWe Have A Variety Of Universal
Stands & Mounts For Every TV Set!
Samsung television. Replacement LED for tv un65f6400af
Question edited for clarity.
ShopJimmy: TV Parts, Universal TV Stands, TV Repair
https://www.shopjimmy.com The online leader in TV repair, replacement TV parts, DLP lamps, Universal TV Stands, LED Strips & more! Fix your LCD, LED, Plasma or DLP TV today!
You've visited this page 2 times. Last visit: 31/01/21
TV Parts
TV Parts · Samsung BN96-29074A/BN96-29075A LED Backlight ...
Samsung TV Parts
We've included a few Samsung TV repair tutorials on this page, but ...
LG TV Parts
We've included a few LG TV repair tutorials on this page, but if you ...
Boards
Shop our replacement TV boards to fix your TV today!
Contact Us
We have a team of friendly and experienced Customer Service ...
LED Strips
Shop our selection of quality LED strips to repair your LED TV today!
  1. More results from shopjimmy.com »
Replacement led for tv un65f6400af
Shop Jimmy for all television parts
TV Parts
Samsung TV Parts
LG TV Parts
Boards
Contact Us
LED Strips
Shop our selection of quality LED strips to repair your LED TV today! More results from shopjimmy.com »
I have a 4k, 50in. LED Onn tv, I need to order a power supply, who can you refer me to, so That I may order the part. Thanks, Joey Bush
Shop Jimmy. Tell him we sent you :>)
OR
brand-ONN - LCD / LED TV REPLACEMENT PARTS ...
moretvparts.com > ... > onn
ONN ONA65UB19E07 TV LED STRIP M08-TP65030-0601N-4270A. $10.00 ... ONN ONA65UB19E07 TV POWER SUPPLY BOARD PW.168W2.802 / ...
onn tv 50" ' eBay
www.ebay.ca > sch
ONN ONA50UB19E05 TV Repair Parts Kit -Version 3 (SEE NOTE). New (Other). C $65.80 ... ONN 50 Inch Roku 100012585 Tv Stand With 2 Screws ... New Onn 100007147-H / JVC LT-50MAW595 Power Supply (TV5006-ZC02-02) E021M289-T1. Brand New ... Onn ONC50UB18C05 4K LED TV EACDJ6E10 T-Con Board.
Television Replacement Parts: Electronics - Amazon.com
www.amazon.com > Television-Replacement-Parts
Results 1 - 24 of 3000+ - Online shopping for Television Replacement Parts from a great ... LB70006 Replacement LED Backlight Strips (12) for Vizio E70-E3 ... BN44-00808D Power Supply Board Compatible for Samsung ... Stream 4K Video ..
Samsung led tv quit working. Replaced all the boards inside, main, power, Tcon and WiFi. Still all i get is blinking red startup light
If one of the led lights in back light strip fails, the power supply senses the current change and shuts down. The LED strips have to be tested to see which one failed.
LG 55LN5700 LED TV. Screen went black, audio works. Flashlight test, able to see pic moving. Replaced LED strips & pwr board. Try turn on, LEDs blink 1x and red light flashes 3x. Let it sit 8hr
Replace the jack wires going to the LED strips. Or look for the one bad jack wire going to the LED's and fix it. Use a volt meter on ohms to find the bad wire.
2answers
My samsung led tv, when i turn on red light blinks 6 times. no display, no sound. Tried replacing power board, main board and tcon board, all of them seems to be fine. What else could be the problem.
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
Samsung lcd tv, no pic but flashlight shows image on screen. Model number un50eh5000fxza
it is a led tv you have problem with led back light strip it is need to replace with a new one (open a display and replace it)
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
